跳至主要内容
WEDA Node v1.1
v1.1.1_20261008.2​
Changes since the previous public release: v1.1.1_20260902.1.
This entry combines the changes included in the intervening v1.1 builds.
Download: WEDA Node Activator installers.
Bug Fixes and Improvements​
  • Credential updates: Update Authentication Credentials now applies the selected file instead of continuing to use the previous credential. If the node cannot use a selected Device Credentials file, the update fails with E5005 and restores the previous credential.
  • Hardware identification: x64 Advantech devices report their actual board model instead of ADVANTECH-EDGE. Removing and reinstalling WEDA Node in the same Activator session also preserves the model used by the device management agent.
  • Service restart: Restart Service no longer leaves WEDA Node without its service containers when restarting on a Docker Compose v1 host. It preserves the network used by AI model secured volumes.
  • Hardware telemetry: Restored the default hardware-information and capability sensors: hwinfo_motherboard, hwinfo_manufacturer, hwinfo_biosrevision, gpio_isSupported, watchdog_isSupported and thermalprotection_isSupported. These sensors report once per day.
  • Installation: Corrected the container image versions selected by the installer and fixed an installation compatibility issue in an Ubuntu 26.04 live environment.
Operational Changes​
  • Updating credentials stops the WEDA services before applying the file, so the device disconnects briefly during the update.
  • Restart failures are reported as E4003 with the Docker Compose error output.
Upgrade Notes​
Caution: Credentials after a model correction
If an x64 device previously registered as ADVANTECH-EDGE, correcting its model changes the key used to protect its saved credential. A node with an Auto Provision master key can provision again. A node using only Device Credentials needs a new credential for the corrected model.
For the credential and activation steps, see Register WEDA Node.
v1.1.1_20260902.1​
What's New​
  • None.
Bug Fixes​
  • Container deployment no longer fails when the container references a registry that requires authorization, such as ACR, Docker Hub, or ECR.
Interface Changes​
  • None.
v1.1.1_20260723.1​
What's New​
  • None.
Bug Fixes​
  • Improved WEDA Node to Core connection status detection.
  • CVE remediation: upgraded Docker to v28.5.3 and containerd to v2.2.4 (CVE-2026-46680), bumped gRPC, and rotated the embedded WEDA CA certificate.
  • AI Model deployment disk/capacity precondition failures are now classified as non-retryable, with a cross-platform disk-usage check.
Interface Changes​
  • None.
