Batch Tasks Management
Overview​
The Batch Tasks Management module in WEDA allows users to create, manage, and execute batch tasks for automating repetitive operations and processing large volumes of data efficiently. This module provides a structured way to define tasks, schedule their execution, and monitor their performance through the WEDA Core API.
Basic Operations​
Basic API URL: https://{domain}/{tenantPath}/{srp}
OperationAPIDescription
Create TaskPOST {Basic API URL}/api/v1/orgs/{orgId}/tasksCreate a new task under an organization
List TasksGET {Basic API URL}/api/v1/orgs/{orgId}/tasksGet list of tasks in a specific organization
Update TaskPUT {Basic API URL}/api/v1/orgs/{orgId}/tasks/{taskId}Update task's details in an organization
Remove TaskDELETE {Basic API URL}/api/v1/orgs/{orgId}/tasks/{taskId}Remove task from an organization
Create BatchPOST {Basic API URL}/api/v1/orgs/{orgId}/batchesCreate a new batch under an organization
List BatchesGET {Basic API URL}/api/v1/orgs/{orgId}/batchesGet list of batches in an organization
Update BatchPUT {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId}Update batch's details in an organization
Remove BatchDELETE {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId}Remove batch from an organization
Constraints & Limitations​
General​
  • API access requires authentication with a valid token
  • Organization must exist
Task: Update​
  • cmd is the command that will be executed.
  • payload is the variables in the payload.
Task: Delete​
  • The task can only be deleted if it is not linked to any batch.
Batch: Create​
  • cronExpression is required and must be a valid cron expression.
  • isEnabled is required, whether the batch is enabled.
  • runOnStartup is required, whether the batch should run on startup.
  • actions is required, which defines the tasks to be executed in the batch.
Batch: Delete​
  • Only batches with isEnabled set to false can be deleted.
Advanced Features​
Task​
Get Task DetailsGET {Basic API URL}/api/v1/orgs/{orgId}/tasks/{taskId}Get details of a specific task in an organization
Batch​
Get Batch DetailsGET {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId}Get details of a specific batch in an organization
Get Task ResultsGET {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId}/resultsGet execution history of a specific task in an organization
Update Batch ActionsPUT {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId}Update the actions of a specific batch in an organization
Trigger Batch ExecutionPOST {Basic API URL}api/v1/orgs/{orgId}/batches/{batchId}:startTrigger the execution of a specific batch in an organization
Get Triggered BatchesGET {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId}/triggersRetrieve the list of batch trigger IDs for a specific batch
Enable/Disable BatchPUT {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId}/statusEnable or disable a specific batch in an organization
Get Device BatchGET {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId}/devicesRetrieve the list of device IDs associated with a specific batch
Last updated on Apr-8, 2026 | Version 1.0.0
