跳至主要内容
Versioning Policy
WEDA Core and WEDA Node are versioned separately. This page explains which version combinations are fully supported, and how WEDA Node keeps itself up to date.
Matching WEDA Core and WEDA Node versions​
WEDA Core and WEDA Node are released on separate lines and carry their own version numbers, so the two numbers are not meant to look identical. Only the first two numbers decide compatibility.
WEDA CoreWEDA Node
Version formatv1.1.2-20260831.2v1.1.1_20260723.1
Decides compatibility1.11.1
No effect on compatibility.2-20260831.2.1_20260723.1
In the example above both are 1.1, so WEDA Node v1.1.1_20260723.1 is fully compatible with WEDA Core v1.1.2-20260831.2.
When the first two numbers do not match, the device keeps working but some features are unavailable.
WEDA CoreWEDA NodeResult
v1.1.2-20260831.2v1.1.1_20260723.1Fully compatible
v1.1.2-20260831.2v1.0.0_20260415.1Device works, some features unavailable
v1.0.0-20260410.1v1.1.1_20260723.1Device works, some features unavailable
WEDA Node automatic upgrades​
WEDA Node keeps its own services up to date on the device. There is no manual upgrade step for you to run.
Automatic upgrades are always on and cannot be turned off in this release. Plan for the behavior below rather than around it.
When upgrades happen​
WEDA Node checks for updates every 5 minutes. There is no maintenance window, so an upgrade can start at any time of day.
What happens on the device​
An upgrade replaces the running services instead of swapping them in place, so the WEDA Node services stop and start again. Expect a service interruption of under 10 seconds.
Checking the installed version​
Run this on the device:
/opt/Advantech/show-weda-versions.sh
Confirming an upgrade succeeded​
Two ways to check:
  • On the device, docker ps shows the state of the WEDA Node services.
  • From WEDA Core, the device's online state and version information are available through the API.
Release notes​
Release notes for each product line are listed under this section, one page per release.
