跳至主要内容
Device Management
Overview
A device in WEDA represents a physical edge machine running WEDA Node — the edge-side agent that connects hardware to WEDA Cloud. Before a device can report telemetry or receive container deployments, it must be registered in WEDA Cloud and activated by running WEDA Node Activator on the physical machine.
Each device is identified by two values reported by WEDA Node Activator:
  • deviceId — the device's MAC address (lowercase, no separators, e.g. cc827f50f406)
  • hwModel — the hardware model string (e.g. MIC-710, ADVANTECH-EDGE)
A device belongs to exactly one Org. Device operations, including telemetry configuration, container deployments, and AI model deployments, are governed by its Org association and the caller's permissions.
SubNode Devices
WEDA also supports SubNode devices — connectors defined in WEDA Edge that represent third-party equipment or Advantech I/O modules. Once configured, SubNode devices receive their own deviceId and appear in the same device list APIs. However, SubNode onboarding and DTDL configuration are handled entirely in WEDA Edge, not through these Cloud APIs. See SubNode for details.
Device Status
StatusMeaning
RegisteredDevice record created in WEDA Cloud; WEDA Node not yet connected
ActivatedWEDA Node has connected and synced; device is fully operational
DeactivatedManually deactivated; device cannot connect to WEDA Core — telemetry stops and new deployments queue until reactivated
Onboarding Flow
Device onboarding spans both WEDA Cloud and the physical edge machine:
Step 1 — Get device identifiers (Edge)
Start WEDA Node Activator on the physical machine. It displays deviceId (Device field) and hwModel (Model field). Copy both values before proceeding.
Step 2 — Register device (Cloud)
Call POST /api/v1/orgs/{orgId}/devices with deviceId and hwModel. The target orgId is provided in the URL path. deviceName is optional — if omitted, WEDA Core auto-generates it as {hwModel}-{deviceId}. The device record is created with status Registered.
Step 3 — Connect WEDA Node (Edge)
Run WEDA Node Activator to install and start the WEDA Node service. Two activation methods are available:
MethodHow it worksWhen to use
Register & Connect device to WEDA site (default)Uses the built-in key bundled with the installer; no file requiredStandard devices connecting to WEDA Cloud
Use Local Credential FileUses a .bin credential file downloaded via APIOffline/LAN environments, pre-provisioned devices
To use the Local Credential method: download the .bin file via Node Activation, place it on the edge device, and select Use Local Credential File in WEDA Node Activator.
Step 4 — Verify activation (Cloud)
Query the device list under the Org and confirm the device status is Activated.
Operations
Provisioning & Registration
OperationAPIDescription
Register DevicePOST /api/v1/orgs/{orgId}/devicesRegister a device and link it to an Org. Requires deviceId and hwModel; orgId is supplied in the URL path. deviceName is optional — see Constraints.
Get Auth InfoGET /api/v1/devices/{deviceId}/authDownload the credential .bin file for local activation.
List All DevicesGET /api/v1/devicesPaginated list of devices the caller has permission to view.
List Devices Under OrgGET /api/v1/orgs/{orgId}/devicesList devices belonging to a specific Org.
Update DevicePATCH /api/v1/devices/{deviceId}Update the device name or move the device to another Org.
Update Device StatusPOST /api/v1/devices/{deviceId}:{status}Activate, deactivate, or reactivate a device.
Delete DeviceDELETE /api/v1/devices/{deviceId}Soft-delete a deactivated device record — see Constraints for current retention behavior.
Device Configuration
Get CapabilitiesGET /api/v1/devices/{deviceId}/capabilitiesHardware capabilities reported by the device.
Get Telemetry ConfigGET /api/v1/devices/{deviceId}/telemetry-configsCurrent sensor sampling settings.
Update Telemetry ConfigPATCH /api/v1/devices/{deviceId}/telemetry-configsEnable/disable sensors or adjust sampling rates.
Add/Update Custom InfoPUT /api/v1/devices/{deviceId}/custom-infoBulk upsert user-defined key-value metadata.
Get Custom InfoGET /api/v1/devices/{deviceId}/custom-infoRetrieve all metadata entries for the device.
Update Single EntryPATCH /api/v1/devices/{deviceId}/custom-info/{key}Modify one metadata value.
Delete Single EntryDELETE /api/v1/devices/{deviceId}/custom-info/{key}Remove one metadata entry.
Delete All Custom InfoDELETE /api/v1/devices/{deviceId}/custom-infoRemove all metadata from the device.
警告
Updating telemetry configuration is asynchronous. A 202 Accepted response means WEDA Core accepted the requested configuration; it does not confirm that the WEDA Node has applied it. Query the telemetry configuration again to verify the result.
Device Data Definitions
Get Data Source DefinitionsGET /api/v1/devices/{deviceId}/data-sourceRetrieve the Data Source definitions reported by the device.
Get Data ObjectsGET /api/v1/devices/{deviceId}/data-objectsRetrieve the device's Data Object definitions.
Get Data Object by IDGET /api/v1/devices/{deviceId}/data-objects/{dataObjectId}Retrieve one Data Object definition.
These APIs return device data definitions. To retrieve current values or historical data, use the Data Engine APIs.
Constraints
Registration
  • A WEDA Node deviceId must contain exactly 12 lowercase letters or digits, with no separators (e.g. cc827f50f406)
  • hwModel is the hardware model string as shown in WEDA Node Activator
  • deviceName is optional at registration. If omitted, WEDA Core auto-generates it as {hwModel}-{deviceId}
    • Maximum length: 128 characters
    • Allowed characters: a-z, A-Z, 0-9, -, _
    • Whitespace and other special characters are not allowed
    • Must be unique within the same Org; comparison is case-insensitive
  • A device can belong to only one Org at a time
Deletion
  • A device must be Deactivated before it can be deleted
  • DELETE /api/v1/devices/{deviceId} is currently a soft delete: the device record no longer appears in queries, but its data is retained. Registering and activating the same device again restores its prior data
  • Historical telemetry stored by the Data Engine is retained regardless of deletion
Planned changes
  • v1.2: deleting a device will also remove its stored telemetry configuration
  • v1.3: device deletion will become a hard delete, to align with Cyber Resilience Act (CRA) requirements
Deactivation
  • A deactivated device remains linked to its Org
  • Containers already running on the device are not stopped — they continue running unaffected
  • The device cannot connect to WEDA Core, so it stops sending telemetry and cannot immediately receive new deployments
  • Any deployment issued while deactivated is queued and delivered automatically once the device reconnects after reactivation
  • Deactivation does not delete the device, its configuration, or its historical telemetry
Scenario
A system integrator onboards the first edge device at a factory site and tags it with asset metadata:
Once Activated, the device begins reporting telemetry. Custom metadata (location, assetTag) helps users identify and search for the device without changing its core registration fields.
Last updated on Jul-17, 2026 | Version 1.1.0
