跳至主要内容
EdgeHub RESTFul APIs - 2.3.0
Changelog​
VersionAuthorUpdate dateComment
2.1.0Sa.Jing / Yuping.Hung2024/02/29First Version
2.2.0ITsung.Shen2024/03/25Organize documentation and add descriptions
2.3.0Sa.Jing / Yuping.Hung2024/04/19Add Chapter 8 & Chapter 9 (for EdgeHub v2.3 or above)Modify 7.1, 7.2 api format (for EdgeHub v2.3 or above)
1. Introduction​
EdgeHub provides a RESTFul API interface that allows users to access the following contents
  • User's authentication
  • Groups
  • Machines (objects)
  • Parameters
  • Parameter's Realtime or Historical data
  • Devices(Gateways)
  • Tag's data
2. How to use​
2.1 Base URL​
Each EdgeHub site can access the EdgeHub RESTFul API URL based on the following pattern
You can also access the API documentation using the following pattern
2.2 Preliminary​
Except for the 3.1 Login API, all other API requests must include the following two headers in the request header
  • Authorization​
    • SSO token of the logged-in user, which can be obtained from the Login API response.
    • Example:
      • Authorization: Bearer
  • IFPTenant​
    • Tenant ID, specifying the tenant to access, so that the relevant resources in the tenant can be obtained, which can be obtained from the Login API response.
    • Example:
      • IFPTenant: VGVuYW50.ZDzj9ydUUDRc55_w
3. Auth APIs​
3.1 Login​
  • Route​
    POST /v2/auth/login
  • Request​
    • Body​
      "username": "string (required)", // SSO user account in email format
      "password": "string (required)", // SSO user's password
      "setCookie": "bool (optional)" // true or false, optional, setting it to true will write a cookie to the browser
  • Response​
    • Body​
      "latency": "string", // API query latency in milliseconds
      "data": {
      "tokenType": "string", // Token type, currently only supports Bearer
      "accessToken": "string", // API access token, which needs to be included in the Authorization header of all subsequent requests
      "expiresIn": "timestamp", // Token expiry date in Unix timestamp format, the token is valid for 1 hour
      "refreshToken": "string", // String in Base64 format, use this key to refresh the token
      "user": {
      "tenants": [ // Login user's tenant information
      "id": "string", // Tenant ID, required for requesting data-related APIs, needs to be included in the header
      "name": "string" // Tenant name
  • Example​
    Request body:
    "username": "sa.jing@advantech.com",
    "password": "abcdefg",
    "setCookie": true // optional, setting it to true will write a cookie to the browser
    Response:
    "latency": "81ms",
    "data": {
    "tokenType": "Bearer",
    "accessToken": "eyJhbGciOiJIUzUxMiIsInR5cCI6IkpXVCJ9.eyJjb3VudHJ5IjoiVFciLCJjcmVhdGlvblRpbWUiOjE2NjczNjY3NDIsImV4cCI6MTY4ODAyNDMwMywiZmlyc3ROYW1lIjoiU2EiLCJpYXQiOjE2ODgwMjA3MDMsImlkIjoiY2I5MmU2M2YtNWE2ZS0xMWVkLTgyNzYtMGE1ODBhZGY0MGNkIiwiaXNzIjoid2lzZS1wYWFzIiwibGFzdE1vZGlmaWVkVGltZSI6MTY2NzM2ODAxOSwibGFzdE5hbWUiOiJKaW5nIiwicmVmcmVzaFRva2VuIjoiOGI2ODQ4OTctMTY0Ny0xMWVlLTg4YmQtMGE1ODBhZGY0MGRiIiwic3RhdHVzIjoiQWN0aXZlIiwidXNlcm5hbWUiOiJzYS5qaW5nQGFkdmFudGVjaC5jb20uY24ifQ.w9wvAPD56nPpOGJKaNyA-R61Wv6DO7k2kQQ4bKojLiXRyq0YoL4AAxyZ_eL5IxCrRtr6Q1ZdGXCRaO5a8mdJSw", // All subsequent requests need to include this token in the Authorization header
    "expiresIn": 1688024303, // Token is valid for 1 hour
    "refreshToken": "8b684897-1647-11ee-88bd-0a580adf40db", // Used for refreshing the token
    "user": {
    "tenants": [
    "id": "VGVuYW50.Y1-NK3QAXhVOdBTZ",
    "name": "Root Tenant"
    "id": "VGVuYW50.ZDet-2iqhavNUEAg", // Required for data-related API requests, needs to be included in the header
    "name": "satest"
3.2 Refresh Token​
  • Route​
    POST /v2/auth/refreshToken
  • Request​
    • Body​
      token: string (required), //string in Base64 format which is got from refreshToken of Login API
  • Response​
    • Body​
      latency: string, // API query latency in milliseconds
      data: {
      tokenType: string, // Token type, currently only supports Bearer
      accessToken: string, // API access token, which needs to be included in the Authorization header of all subsequent requests
      expiresIn: timestamp, // Token expiry date in Unix timestamp format, the token is valid for 1 hour
      refreshToken: string, // String in Base64 format, use this key to refresh the token
  • Example​
    Request body:
    token: 20df5ce0-165e-11ee-88bd-0a580adf40db
    Response:
    latency: 9ms,
    data: {
    tokenType: Bearer,
    accessToken: eyJhbGciOiJIUzUxMiIsInR5cCI6IkpXVCJ9.eyJjb3VudHJ5IjoiVFciLCJjcmVhdGlvblRpbWUiOjE2NjczNjY3NDIsImV4cCI6MTY4ODAzNDA1MSwiZmlyc3ROYW1lIjoiU2EiLCJpYXQiOjE2ODgwMzA0NTEsImlkIjoiY2I5MmU2M2YtNWE2ZS0xMWVkLTgyNzYtMGE1ODBhZGY0MGNkIiwiaXNzIjoid2lzZS1wYWFzIiwibGFzdE1vZGlmaWVkVGltZSI6MTY2NzM2ODAxOSwibGFzdE5hbWUiOiJKaW5nIiwicmVmcmVzaFRva2VuIjoiM2RhNmUxZmYtMTY1ZS0xMWVlLTg4YmQtMGE1ODBhZGY0MGRiIiwic3RhdHVzIjoiQWN0aXZlIiwidXNlcm5hbWUiOiJzYS5qaW5nQGFkdmFudGVjaC5jb20uY24ifQ.Jmoooaz01KFPdgJhJYOv763m91JIhFCNkaxZzMmlPg4wHEKRvChu-0IqOcdoUuB0JCvoWqvXGSIdjipFBs8y3A,
    expiresIn: 1688034051,
    refreshToken: 3da6e1ff-165e-11ee-88bd-0a580adf40db
3.3 Set my tenant​
  • Route​
    POST /v2/auth/setMyTenant
  • Request​
    • Body​
      tenantId: string (required), //string of tenant id, get it from login API
  • Response​
    Status: 200 OK
  • Example​
    Request body:
    tenantId:VGVuYW50.ZCI4Q928Cafk07SD
    Response:
    Status: 200 OK
3.4 Logout​
  • Route​
    POST /v2/auth/logout
  • Request​
    N/A​
  • Response​
    Status: 200 OK​
  • Example​
    Request body:
    N/A
    Response:
    Status: 200 OK
4. Groups APIs​
4.1 Get groups​
  • Route​
    GET /v2/groups
  • Request​
    • Header
      KeysTypeDescription
      AuthorizationstringSSO token of the logged-in user, Bearer token, can be obtained from the Login API response.
      IFPTenantstringTenant ID, specifies the tenant to access, can be obtained from the Login API response.
    • Body​
      N/A
  • Response​
    • Body​
      latency: string, //API query latency in millisecond
      data: {
      groups: [
      id: string, // Group ID
      _id: number, // Group ID (internal used)
      parentId: string, // Parent group ID
      _parentId: number, // Parent group ID (internal used)
      tenantId: string, // Tenant ID
      sourceName: string,// Group name, as a key in DB
      owner: string, // Tenant owner's account, in email format
      timeZone: string, // Asia/Taipei
      timeZoneInfo: {
      label: string, //(GMT+08:00) Asia/Taipei
      timeZone: string, //Asia/Taipei
      utcOffset: int, // 480
      "depth": int, // Group level
      "coordinate": {
      longitude: number, // Group longitude
      latitude: number, // Group latitude
      "address": string, // Group address
      "address2": string, // Group address
      "city": string, // Group city
      "postalCode": string, // Group postal code
      "createdAt": string, // Group created time
      "updatedAt": string, // Group last updated time
      "img": string, // Group image
      "enable": bool, // Group status
      "name": [ // Multi-language of group name
      lang: string, // en-US,zh-CN,zh-TW,ja-JP
      text: string, // group name
      "description": [ // Multi-language of group description
      lang: en-US,// en-US,zh-CN,zh-TW,ja-JP
      text: PM Test, // group description
      "descendants": [
      // descendants group object, same structure of this object
  • Example​
    Request:
    GET https://api-hub-deviceon-bi-master-ensaas.edge365.advantech.com/v2/groups
    Response:
    latency: 28ms,
    data: {
    groups: [
    _id: 1122,
    parentId: null,
    _parentId: null,
    tenantId: VGVuYW50.ZWb-tfKRKUpOavef,
    sourceName: PM Test,
    owner: tracy.su@advantech.com.tw,
    timeZone: Asia/Taipei,
    timeZoneInfo: {
    label: (GMT+08:00) Asia/Taipei,
    utcOffset: 480
    "depth": 1,
    "coordinate": {
    longitude: 0.0000000000,
    latitude: 0.0000000000
    "address": null,
    "address2": null,
    "city": "",
    "postalCode": "",
    "createdAt": "2023-11-29T09:04:54.089Z",
    "updatedAt": "2023-11-29T09:04:54.089Z",
    "img": "",
    "enable": true,
    "name": [
    lang: en-US,
    text: PM Test
    lang: zh-CN,
    text: PM Test
    lang: zh-TW,
    text: PM Test
    lang: ja-JP,
    text: PM Test
    "description": [
    lang: en-US,
    text: PM Test
    lang: zh-CN,
    text: PM Test
    lang: zh-TW,
    text: PM Test
    lang: ja-JP,
    text: PM Test
    "descendants": []
5. Machines APIs​
5.1 Get machines (objects) of a group​
  • Route​
    GET /v2/machines/{groupId}
  • Request​
    • Query string
      KeysTypeRequiredDescription
      groupIdstringYGroup ID, can be obtained from 4.1 Get groups API
      isStationbooleanNfilter by isStation prop
      showGroupObjectbooleanNquery GroupObject or not,default is true
      searchstringNsearch by machine name
      searchLangstringNsearch language Valid value:en-US,zh-CN,zh-TW,ja-JP.Default is en-US.
      skipnumberNskipped page number
      limitnumberNnumber of records per page
      sortbystringNThe property name which resources order by[CREATED_AT,UPDATED_AT,NAME,MACHINE_TYPE,PARAMETER_COUNT].Default is CREATED_AT
      orderstringNSort directions,valid value:ASC,DESC.Default is ASC
    • Header
      KeysTypeDescription
    • Body​
      N/A
  • Response​
    • Body​
      data: {
      machines: [
      id: string, // Machine ID
      _id: number, // Machine ID (internal used)
      groupId: string, // Group ID
      _groupId: number, // Group ID (internal used)
      tenantId: string, //Tenant ID
      sourceName: string, //Machine en-US name
      createdAt: string, // Machine created time
      updatedAt: string, // Machine last updated time
      machineType: {
      parentKey: string,//Machine parent type
      key: string, //Machine type
      "isGroupObject": boolean,//Machine is group object or not,group object is automatically created by the system when creating a group
      "tmplTypeId": number, //Machine type id(internal used)
      "tmplTypeName": string, //Mahicne type name(internal used)
      "img": string, //Machine image
      "serialNumber": string, //Machine serial number
      "almCodeFile": string, //Machine alarm code file,used for alarm setting
      "additionalMsgUrl": string, //Machine additional url,used to navigate to other machine-related links.
      "minKeptDays": number, //Machine min data saved days
      "otherKeptDays": number,//Machine hour,day data saved days
      "name": [ // Multi-language of machine name
      text: string // machine name
      "description": [ // Multi-language of machine description
      text: string // machine description
      "machineCount":3,//the total number after filter and search
  • Example​
    Request:
    GET https://api-hub-deviceon-bi-master-ensaas.edge365.advantech.com/v2/machines/R3JvdXA.MTEyMg?skip=1&limit=5&search=obj&showGroupObject=false
    Response:
    latency: 18ms,
    data: {
    machines: [
    _id: 29052,
    groupId: R3JvdXA.MTEyMg,
    _groupId: 1122,
    sourceName: Obj01,
    createdAt: 2023-12-01T02:25:49.294Z,
    updatedAt: 2023-12-01T02:25:49.254Z,
    machineType: {
    parentKey: default,
    key: DefaultEquipType
    "isGroupObject": false,
    "tmplTypeId": 0,
    "tmplTypeName": "Default",
    "img": "",
    "serialNumber": "",
    "almCodeFile": "",
    "additionalMsgUrl": "",
    "minKeptDays": 7,
    "otherKeptDays": 731,
    "name": [
    lang: en-US,
    text: Obj01
    lang: zh-CN,
    text: Obj01
    lang: zh-TW,
    text: Obj01
    lang: ja-JP,
    text: Obj01
    "description": [
    lang: en-US,
    text:
    lang: zh-CN,
    text:
    lang: zh-TW,
    text:
    lang: ja-JP,
    text:
    "machineCount":3,
6. Parameters APIs​
6.1 Get parameters of a machine (object)​
  • Route​
    GET /v2/parameters/{machineId}
  • Request​
    • Query string
      machineIdstringYMachine (object) ID, can be obtained from 5.1 Get machines API
      valueTypesstring[]Nfilter by valueTypes, values in [Number,String,Discrete]
      kindsstring[]Nfilter by kinds, values in [Constant,Calculation,undefined], undefined means primitive
      alarmbooleanNwhether to query parameters with alarms set.default id false
      afternumberNquery after cursor
      beforenumberNquery before cursor
      firstnumberNquery first records number
      lastnumberNquery last records number
      sortbystringNThe property name which resources order by.[NAME,CREATED_AT,UPDATED_AT,KIND,UNIT,ALM_FLAG,RECORDING_RATE].Default is CREATED_AT
      orderstringNSort directions.Valid value:ASC,DESC.Default is ASC
    • Header
      KeysTypeDescription
    • Body​
      N/A
  • Response​
    • Body​
      data: {
      parameters: [
      id: string, //Parameter ID
      _id: string, //Parameter ID (internal used)
      machineId: string, //Machine ID
      _machineId: number, //Machine ID(internal used)
      name: string, //Parameter name
      scadaId: string,//the gateway scadaId associated with this primitive parameter
      tagId: string,//the gateway tag name associated with this primitive parameter
      valueType: string, //[Number,String,Discrete]
      kind: string, //[Constant,Calculation,undefined]
      defaultValue: string,//only constant and calculation can set parameter default value
      decimalPrecision: number, //Parameter decimal precision
      unit: string, //Parameter unit
      spanHi: number,//Parameter spanHi
      spanLo: number,//Parameter spanLo
      recordingType: string,//Parameter recording type ,[Current,Cumulative]
      recordingRate: number,//Parameter recording rate
      maxChangeRatePerMin: number,//Cumulative parameer return the maximum change per minute, while current parameter return the maximum change rate per minute.
      recordingGroup: number, //not using it now
      dataKeptDays: number,//Parameter raw data saved days
      stateTxt: string,//Discrete parameter's state descriptor
      negativeMode: boolean,//if support negative mode
      almFlag: number,// 0:no set alarm 1:set alarm but not enable 3:set and enable alarm
      calcFormula: string,//Calculation parameter's formula (internal format)
      calcFreq: number,//calculation rate
      calcFormulaDisplay: string, //Calculation parameter's formula
      createdAt: string,//Parameter created time
      updatedAt: string,//Parameter last updated time
      cursor: string,
      description: [ // Multi-language of parameter description
      lang: string , // en-US,zh-CN,zh-TW,ja-JP
      text: string // parameter description
      "parameterCount":3,//the total number after filter and search
  • Example​
    Request:
    GET https://api-hub-deviceon-bi-master-ensaas.edge365.advantech.com/v2/parameters/TWFjaGluZQ.MjkwNTI?first=5&kinds[]=undefined&kinds[]=Constant&sortby=NAME
    Response:
    latency: 9ms,
    data: {
    parameters: [
    _id: 29052&Con01,
    machineId: TWFjaGluZQ.MjkwNTI,
    _machineId: 29052,
    scadaId: b97457ef-9f91-4400-8b67-7a66dee94e9e,
    tagId: Con01,
    valueType: Number,
    kind: Constant,
    defaultValue: 0,
    decimalPrecision: 0,
    unit: ,
    spanHi: 100,
    spanLo: 0,
    recordingType: Current,
    recordingRate: 0,
    maxChangeRatePerMin: 100,
    recordingGroup: 0,
    dataKeptDays: 7,
    stateTxt: ,
    negativeMode: false,
    almFlag: 0,
    calcFormula: ,
    calcFreq: 0,
    calcFormulaDisplay: ,
    createdAt: 2023-12-01T02:26:24.086Z,
    updatedAt: 2023-12-01T02:26:23.983Z,
    cursor: UGFyYW1ldGVy.MjkwNTImQ29uMDE,
    description: [
    lang: en-US,
    text:
    lang: zh-CN,
    text:
    lang: zh-TW,
    text:
    lang: ja-JP,
    text:
    "parameterCount":3,
7. Parameter's data APIs​
7.1 Get parameter's original calculated data​
GET /v2/parameter/HIS/original/calculatedData
[ 129590, 126000, 129590, 127795, 1701990000000, 0 ],[ 133190,//max value 129600,//min value, 133190,//last value, 131395,//avg value, 1701993600000,//datatime 0//quality ]
fieldList: [
maxvalue,
minvalue,
lastvalue,
avgvalue,
datatime,
quality
7.2 Get parameter's original raw data​
GET /v2/parameter/HIS/original/rawData
[ 129590, 0, 1701993590000 ],[ 129600, 0, 1701993600000 ]
fieldList: [
datavalue,
quality,
datatime
7.3 Get parameter's autoscale data​
GET /v2/parameter/HIS/:method/data
method: autoScale or fixedScale
[ 6495111, 0, 1693327200000 ], [ 6495711, 0, 1693327800000 ], ], interval: 600000, nextData: [ 6498171, 0, 1693328400000 ], previousData: [ 6494511, 0, 1693326600000 ]
7.4 Get parameter's latest data​
GET /v2/parameter/RT/data
  • Request​
    • Header​
      IFPTenant: TenantId (string)
      Cookie: include EIToken (string)
    • Parameter​
      KeysTypeRequiredDescribe
      id[]stringYparameter id
      beforeintNdata before this timestamp(second)
      afterintNdata after this timestamp(second)
      includeBeforebooleanNdata include before timestamp or not
      includeAfterbooleanNdata include after timestamp or not
  • Response​
    • Body​
      data: {
      datapoints: [
      quailty: int,
      timestamp: timestamp in milliseconds,
      value: float or string (depend on data)
      "latency": string
  • Example​
    GET http://api-hub-deviceon-bi.edgehub.com/v2/parameter/RT/data?id=UGFyYW1ldGVy.NDA0MyZDYWxDdW0
    Response:
    data: {
    datapoints: [
    quailty: 0,
    timestamp: 1708596913001,
    value: 292301
    "latency": "5.479707ms"
7.5 Set parameter's data​
POST /v2/parameter/RT/data
  • Request​
    • Header​
      Authorization : Bearer EIToken (string)
    • Body​
      paramValue: [
      value: float or string (depend on data),
      type: int // 1 = analog, 2 = discrete, 3 = text
      "latency": string
  • Response​
    • Body​
      data: {
      message : string
      "latency": string
  • Example​
    POST http://api-hub-deviceon-bi.edgehub.com/v2/parameter/RT/data
    Request body:
    paramValue:[
    value: 100,
    type: 1,
    value: 101,
    type: 3,
    Response:
    data: {
    message : OK
    "latency": "200 ms"
7.6 Get parameter's statistic data (discrete data type)​
GET /v2/parameter/statistic/discrete/:op
op: only support sum
7.7 Get parameter's statistic data (analog data type)​
GET /v2/parameter/statistic/analog/:op
op: support avg and sum
8. Device and Device tags APIs​
8.1 Get devices​
  • Route​
    GET /v2/gateways
  • Request​
    • Header
      KeysTypeDescription
    • Query string
      kindsstring[]Nfilter by gateway kinds
      searchstringNsearch by gateway name
      sortbystringNThe property name which resources order by[CREATED_AT,UPDATED_AT,NAME,GATEWAY_TYPE].Default is NAME
    • Body​
      N/A
  • Response​
    • Body​
      data: {
      gateways: [
      id: string, //Gateway ID
      kind: string,//[DcADAM,DcWISE,DcEdgeLink,DcSCADA,DcGeneralPC,DcIfpConnector,WebAccess,EdgeLink,IfsGateway,WoAgent,Prediction,MachineCloud]
      scadaId: string,//Gateway scadaId
      createdAt: string,//Gateway created time
      desc: string,//Gateway description
      mode: number,//device mode,0=Construction,1=Operation
      img: string,//Gateway image
      protocolType: number,//Gateway protocol type 0=undefined, 1=Scada, 2=EdgeLink, 3=NBIoT(Coap), 4=iSensing, 5=SmartWorx, 6=DCIFPConnector for worker use
      deviceMac: string,//Gateway mac
      credentialKey: string,//mqtt credential
      nbiotVhost: string,//Gateway nbiot vhost
      hwVersion: string, //Gateway Hardware Version
      fwVersion: string, //Gateway Firmware Version
      swVersion: string, //Gateway Software Version
      updatedAt: string,//Gateway updated time
      username: string, //iothub credential username
      password: string, //iothub credential password
      isSystemTimestamp: boolean,//use platform timestamp or not
      currentStatus: {//Gateway current status
      time: string, //Gateway last data time
      status: boolean,//Gateway is active or not
      savedAt: string//Gateway last data time
      "gatewayCount": 5,//the total number after filter and search
  • Example​
    Request:
    GET https://api-hub-deviceon-bi-master-ensaas.edge365.advantech.com/v2/gateways?kinds[]=DcSCADA&kinds[]=DcADAM&skip=1&limit=5&sortby=CREATED_AT&order=DESC&search=1
    Response:
    latency: 9ms,
    data: {
    gateways: [
    tenantId: VGVuYW50.ZgUPdqt9N0ZgllYt,
    kind: DcSCADA,
    scadaId: 2c016450-f7a4-11ee-93bd-979b2351cfa4,
    createdAt: 2024-04-11T01:38:26.285Z,
    desc: ,
    mode: 1,
    img: ,
    protocolType: 1,
    deviceMac: ,
    credentialKey: d40b067f74f6ed29118c3a10917137gz,
    nbiotVhost: null,
    hwVersion: ,
    fwVersion: ,
    swVersion: ,
    updatedAt: 2024-04-11T01:38:26.285Z,
    username: null,
    password: null,
    isSystemTimestamp: false,
    currentStatus: {
    time: 2024-04-11T07:29:39Z,
    status: false,
    savedAt: 2024-04-11T07:29:39Z
    "gatewayCount": 5
8.2 Get device by device ID​
  • Route​
    GET /v2/gateways/{scadaId}
  • Request​
    • Query string
      scadaIdstringYGateway scadaId, can be obtained from 8.1 Get devices api
    • Header
      KeysTypeDescription
    • Body​
      N/A
  • Response​
    • Body​
      data: {
      gateway: {
  • Example​
    Request:
    GET https://api-hub-deviceon-bi-master-ensaas.edge365.advantech.com/v2/gateways/4360cf10-f618-11ee-b196-fb447c5772f3
    Response:
    latency: 9ms,
    data: {
    gateway: {
    kind: DcSCADA,
    scadaId: 4360cf10-f618-11ee-b196-fb447c5772f3,
    createdAt: 2024-04-09T02:24:31.374Z,
    desc: ,
    mode: 1,
    img: ,
    protocolType: 1,
    deviceMac: ,
    credentialKey: 9f7c06dee2b1423cbcd1bf47764db6w6,
    nbiotVhost: null,
    hwVersion: ,
    fwVersion: ,
    swVersion: ,
    updatedAt: 2024-04-09T02:24:31.374Z,
    username: null,
    password: null,
    currentStatus: {
    status: false,
8.3 Get tags by device​
  • Route​
    GET /v2/tags/{gatewayId}
  • Request​
    • Query string
      gatewayIdstringYGateway ID, can be obtained from 8.1 Get devices api
      searchTagIdstringNsearch by tagId
      valueTypesstring[]Nfilter by tag value types, value in [UnKnow,Number,String,Discrete]
      tagIdsstring[]Nquery by multi tagIds
      includeBlocksbooleanNinclude Blocks or not,default is true
      blockstringNsearch by block name
    • Header
      KeysTypeDescription
    • Body​
      N/A
  • Response​
    • Body​
      data: {
      tags: [
      id: string,//Tag ID Base64(Tag).Base64(GatewayID:TagName)
      tagId: string,//Tag name
      valueType: string, //[UnKnow,Number,String,Discrete]
      connectionStatus: {
      status: boolean,//Tag connection status
      ts: string //Tag updateTime
      "createdAt": string,//Tag updateTime
      "updatedAt": string,//Tag updateTime
      "dcUpdateTime": string,//Tag updateTime
      "dcDataTime": string,// Tag data
      "dcDataValue": number,//Tag value
      "dcQuality": number,//Tag quality number
      "dcIsNum": boolean,//Tag is number or not
      "dcBlockType": string,//Tag block type
      "dcSpanHi": number,//Tag spanHi
      "dcSpanLo": number,//Tag spanLo
      "dcDecimalPrecision": number,//Tag Decimal Precision
      "dcStateTxt": string,//Discrete parameter's state descriptor
      "dcDesc": [],// Tag desription
      "dcRecordData": boolean// Tag record data or not
      "tagCount": 5,//the total number after filter and search
  • Example​
    Request:
    GET https://api-hub-deviceon-bi-master-ensaas.edge365.advantech.com/v2/tags/R2F0ZXdheQ.MzUz?searchTagId=tag&valueTypes[]=Number&skip=1&limit=5&includeBlocks=true
    Response:
    latency: 9ms,
    data: {
    tags: [{
    tagId: #MSYS_EdgeStatus,
    valueType: Discrete,
    isAcquiring: false,
    saveToHistory: false,
    connectionStatus: {
    status: true,
    ts: 2024-04-18T06:19:46Z
    "createdAt": "2024-04-18T06:19:46Z",
    "updatedAt": "2024-04-18T06:19:46Z",
    "dcUpdateTime": "2024-04-18T06:19:46Z",
    "dcDataTime": "2024-04-18T06:19:46Z",
    "dcDataValue": 0,
    "dcQuality": 0,
    "dcIsNum": true,
    "dcBlockType": "",
    "dcSpanHi": 1,
    "dcSpanLo": 0,
    "dcDecimalPrecision": 0,
    "dcStateTxt": "",
    "dcDesc": [],
    "dcRecordData": true
    "tagCount": 101
9. Device tags' data APIs​
9.1 Get tag's original calculated data​
GET /v2/device/HIS/original/calculatedData
fieldList: [
maxvalue,
minvalue,
lastvalue,
avgvalue,
datatime,
quality
9.2 Get tag's original raw data​
GET /v2/device/HIS/original/rawData
fieldList: [
datavalue,
quality,
datatime
9.3 Get tag's autoscale data​
GET /v2/device/HIS/:method/data
9.4 Get tag's latest data​
GET /v2/device/RT/data
  • Request​
    • Header​
    • Parameter​
      id[]stringYtag id
  • Response​
    • Body​
      data: {
      datapoints: [
      quailty: int,
      "latency": string
  • Example​
    GET http://api-hub-deviceon-bi.edgehub.com/v2/device/RT/data?id=VGFn.MTIzNDphYmM
    Response:
    data: {
    datapoints: [
    quailty: 0,
    value: 292301
9.5 Set tag's data​
POST /v2/device/RT/data
  • Request​
    • Header​
    • Body​
      tagValue: [
  • Response​
    • Body​
      data: {
      message : string
      "latency": string
  • Example​
    POST http://api-hub-deviceon-bi.edgehub.com/v2/device/RT/data
    Request body:
    tagValue:[
    value: 100,
    value: 101,
    Response:
    data: {
    message : OK
    "latency": "200 ms"
9.6 Get tag's statistic data (discrete data type)​
GET /v2/device/statistic/discrete/:op
9.7 Get tag's statistic data (analog data type)​
GET /v2/device/statistic/analog/:op
