System-Managed DataStreams
Data Engine Pipeline
Device → DataStream (managedBy: System) → Analyzer (optional) → DataStream (managedBy: User) → Alert Policy / Bridge
Overview
When a device connects, WEDA Node reports its sensor capability and WEDA Core automatically syncs each reported sensor into a DataStream with managedBy: System. There is no separate "Data Source" entity or endpoint to query first — the device's sensor list and its DataStreams are the same lookup: GET .../data-streams.
A System-managed DataStream is:
  • Read-only for identity/lineagedataStreamName, dataType, and dataSource come from the device and cannot be changed via the API
  • Editable for displaydisplayName, description, unitDisplay, and recordToDataLake can be updated (PATCH)
  • Traceable to its origindataSource.type is WedaNode or WedaSubNode; dataSource.sourceEntityId is the underlying sensor resource ID reported by the device
Discover a Device's DataStreams
OperationAPIDescription
List DataStreamsGET /api/v1/orgs/{orgId}/devices/{deviceId}/data-streamsAll DataStreams for a device, including their dataSource lineage
Get DataStreamGET /api/v1/orgs/{orgId}/devices/{deviceId}/data-streams/{dataStreamId}One DataStream by ID
Filter the list by managedBy=System to see only device-originated streams, or managedBy=User to see streams created directly (e.g. Analyzer outputs).
System Agent Metric Types
For a device running WEDA Node, the built-in System Agent reports hardware and system metrics. WEDA Core then auto-syncs the corresponding DataStreams. The following names are examples; call GET /api/v1/orgs/{orgId}/devices/{deviceId}/data-streams to discover the DataStreams exposed by a specific device and configuration.
System Resources (all platforms)
MetricTypeExample DataStreamsUnit
cpucpu_usage, cpu_load1, cpu_load5, cpu_load15, cpu_context_switches%, count
memorymemory_total, memory_available, memory_used, memory_usage_percentbytes, %
diskdisk_usage_percent, disk_total, disk_available, disk_reads_completed%, bytes, count
networknetwork_bytes_sent, network_bytes_received, network_errors_inbytes, count
systemsystem_time, system_boot_time, system_procs_runningUnix ms, count
gpugpu_utilization%
disk requires a MountPoint parameter (e.g. / or C:\). network requires an Interface parameter (e.g. eth0).
Hardware Sensors (Advantech industrial PCs)
Requires the Advantech SUSI driver. Available on Advantech industrial computers by default.
MetricTypeWhat it reports
hwinfoMotherboard name, BIOS revision, driver version, EC revision
temperatureAll temperature sensors as a dictionary (key = sensor name e.g. CPU, value = °C)
voltageAll voltage rails as a dictionary (key = rail name e.g. +3.3V, value = V)
fanspeedAll fan speeds as a dictionary (key = fan name e.g. CPU_Fan, value = RPM)
Hardware Functionality (Advantech industrial PCs)
gpioGPIO pin states
watchdogTimer IDs, capability, and current configuration
thermalprotectionProtection zones, source sensor, event type, and shutdown temperature
note
If the SUSI driver is not installed, hardware-specific metrics are silently skipped — system resource metrics continue collecting normally.
Other device types
SubNode devices expose different DataStreams based on their device definition. The metric types above apply only to WEDA Node's built-in System Agent. Call GET /api/v1/orgs/{orgId}/devices/{deviceId}/data-streams to discover the actual DataStreams a specific device exposes.
Constraints
  • System-managed DataStreams cannot be deleted, and only displayName/description/unitDisplay/recordToDataLake can be updated — attempting to change dataStreamName or dataType returns 409
  • A System-managed DataStream becomes available only after WEDA Node reports and syncs the device's capability with WEDA Core
  • A System-managed DataStream's identity is tied to dataSource.sourceEntityId — the sensor's resource ID, assigned by the system and not settable by clients. If the same resource ID is reported again after the device was deleted and re-registered in the same Org, it resolves to the existing DataStream instead of creating a new one, so the stream's history continues. DataStreams are Org-scoped, so this does not carry across Orgs
  • The sensors exposed by a SubNode depend on its device definition
Last updated on Aug-1, 2026 | Version 1.1.1
