User & Role Management
Overview​
WEDA manages user access across two separate tiers. Understanding this separation is essential before making any user management API calls.
TierManaged byRolesPurpose
TenantWISE PortalTenant Admin, Tenant UserEstablishes the user's identity and membership in an independent Tenant
OrgWEDA CoreadminControls access to resources scoped to a specific Org
A user must exist at the Tenant level in WISE Portal before they can be assigned to any Org via the WEDA Core.
Tenant-level Management (WISE Portal)​
Tenant-level user management is handled in WISE Portal, not through WEDA Core.
  • Tenant Admin — full control over the entire WEDA deployment: create/delete Orgs, invite or remove Tenant Users, move devices across Orgs.
  • Tenant User — a user who exists in the Tenant and can be assigned to specific Orgs by a Tenant Admin or Org Admin.
If you purchased a full on-premises deployment, you manage your own Tenant in WISE Portal. If you are on SaaS, Advantech provisions your Tenant and you can add your own Tenant Admins and Tenant Users from WISE Portal.
WEDA Core only manages Org-level assignments. To invite a new user to the system for the first time, use WISE Portal.
Org-level User Management (WEDA Core)​
Once a user exists in the Tenant, a Tenant Admin or an admin of the target Org can assign that user to the Org and grant them an Org role.
Operations​
OperationAPIDescription
Add Users to OrgPOST /api/v1/orgs/{orgId}/usersAdd one or more existing Tenant Users to an Org. All items validated atomically — if any fails, none are inserted.
List Org UsersGET /api/v1/orgs/{orgId}/usersPaginated list of users in a specific Org.
Get Org UserGET /api/v1/orgs/{orgId}/users/{userId}Get a user's details within an Org context.
Remove User from OrgDELETE /api/v1/orgs/{orgId}/users/{userId}Remove a user from an Org and all of its Sub Orgs. Does not delete the user from the Tenant.
List UsersGET /api/v1/usersPaginated list of application users visible to the current caller within the Tenant authorization boundary.
Get UserGET /api/v1/users/{userId}Get a user's profile when the caller has permission to view that user.
Get User's Orgs & RolesGET /api/v1/users/{userId}/orgsList the user's visible Org memberships and role in each Org.
Org Roles​
RoleCapabilities
adminManage users, devices, container stacks, registry credentials, AI models, and Org-scoped data
Currently, admin is the only accepted Org role.
Other role values are not supported yet
The API schema may also display super_admin, operator_, and viewer. These values are reserved for future RBAC support and are not supported end-to-end in the current release. Use only admin.
Constraints​
Adding users to an Org
  • userId must refer to a user who already exists in the Tenant (created via WISE Portal)
  • orgRole must be admin (the only accepted value in v1.1)
  • If the target Org has a parent, the user must already be an admin in the parent Org before they can be added to the child Org
  • For deeper hierarchies, repeat the assignment at each level; a user cannot skip a parent and be added directly to a descendant Org
  • If any user in a batch request fails validation, the entire batch is rejected (atomic)
Changing a role
  • There is no API for changing a user's Org role. orgRole is set when the user is added and cannot be modified afterwards
  • This has no practical effect while admin remains the only accepted value — it becomes relevant once additional roles are supported
Removing
  • An admin cannot remove their own Org membership
  • The last admin in an Org cannot be removed
  • Removing a user from an Org also removes their membership from all Sub Orgs beneath it
  • The user still exists in the Tenant, and memberships in unrelated Org branches are not affected
Removing a parent membership cascades
Before removing a user from an Org, verify whether they still need access to any of its Sub Orgs. All descendant memberships are removed in the same operation.
Scenario​
A system integrator assigns a factory engineer to an existing Org hierarchy within a Tenant:
Once the engineer is added to Sub Org A, they can independently manage that Org's devices, stacks, models, data, and users without needing SI involvement.
Last updated on Aug-1, 2026 | Version 1.1.1
